The 774 is an OT, primaries are red-blue-red, secondaries areorange, black, green and yellow. PT has two red, one red/blue, two green, two yellow, and one red/yellow, I know what these are. Then it's got two black, one white, one orange, one black/white and one black/yellow.
Those were the only numbers on the trannies, thanks.
Compare them to xformers with the same last 3 digits at Mojotone.
Check mounting spacings.
They are probably not original fitment "Fender" xformers, I suspect (it is just a suspicion) they are aftermarket reproductions 50W PT w/export primaries & 50W 2x6L6 OT with 2, 4 & 8ohm taps.
Do they look about the right size, what did they come out of?
As for the wiring legend, unless someone pipes up who has the same items, you may have to ask about with suppliers until they can ID them for sure.
They have Fender stamped into the bells right above the numbers. I really don't know what they came out of. If anyone has a schem for a Prosonic could you check that for trannie numbers?
Fender.com has schematics in the Support section for nearly all the 90's amps onwards.
Prosonic part no's are 049009 OT, 049110 PT. Whether part no's match the number stamped on your xformer is another thing. Wire colours do not appear to match your xformers.
Thanks for that info. I got these from a shop and I remember the guy telling me he pulled them out at the request of a customer that wanted Mercury Mag trannies put in, there was nothing wrong with them. The shop has since closed down. I'll keep digging.
I hope they respond promptly. I find that in cases where I want something out of the ordinary, I get best results calling on the phone. That way I get to be friendly with a human rather than be email #427 for the day, and they usually take care of me on the spot instead of putting it aside for when they have free time. I am not referring specifically to Fender, just in general.
alden at Heyboer said he thinks it's a Westlake out of Westlake Village, Ca. based on the 099 EIA code but I'm not having any luck googling them up either.
Thanks, They match a couple of these with the last three numbers on this page. I called Mojo two days ago and they said the numbers didn't match anything they had. Last nite a guy posted this page on another board. Thanks for the help guys.
