PV CS1000X schematic and layout
  • PV CS1000X schematic and layout
    I have a cs1000 where I believe the drivers might be in the wrong spots. Ch A doesn't have much in common with ch B. Can anyone send me schematic and parts layout.
    I can scan a copy and send it to you.
      Twist's offer is generous, but really, Peavey will send you any schematic for the asking, just contact their parts department. And then you will get a PDF you can expand.
      The schematic set on those is multiple pages including parts lists. The drawings are 11x17 I believe, which means two part scans unless you have a large scanner. The factory scans are full size.
