Hey Guys!
I've got this Marshall JCM900 amp head (model 4500). That has a crackling noise when you strum a chord. It only happens on channel A. Channel B works fine.
I've checked for opened resistors, shorted caps and diodes. I've swapped both preamp and power tubes, changed out a broken preamp tube socket, and resoldered all connections. Still the same problem. By looking at the schematic, I'm starting to suspect a bad ic. Could this be possible? Any hints and ideas would be great, because the owner of this amp (the customer) won't leave me alone. He calls constantly.
Thanks!
Thanks!
