I have a Crate V5112 tube amp, I know I know, I shoulda bought a real amp, that aside.
Today I was playing it as always and the power went out, got my meter and the power fuse was blown, got another fuse, amp powered up, started playing it, after about the 3rd note the fuse blew again. The only thing I have noticed is in the last few weeks it has been noisier than usual as far as 60 cycle hum, I turned off my computer monitor and it seemed fine, hardly any noise at all. This all started today after I swapped out the neck PU in my tele, It had a short in the PU so i fixed it, installed it and didnt realise I caught it under the small e string, plugged it in and very loud humming, the fuse blew then. Fixed the PU again, installed it carefully this time, Played it about 3 seconds and the fuse blew again.
Question: The fuse I replaced the old one with is a fast blow 2amp 250vlt buss fuse. It has the single strand of thin filament, the original had a coiled type filament, same value, 2amp 250vlt. Is the fuse I have now not going to work because it is a fast blow?
Thanks for any help, I am not a wiz at electronics so all help is very much appreciated. Thanks.
