Hey guys, got a slight problem.
The amp in question is a 50w, 4 input from 1976. It had been previously modded with a master volume. My buddy wanted it returned to stock. I did this and it sounded great. The next time I turned it on, however, there was very low output. The pin voltages are all pretty close, though the B+ is lower than I would expect at 402v. Also, whenever I run sound through it, the output tube bias jumps like crazy, from 20 to almost 100. I'm hoping that this might give a clue as to what the matter is. I've changed tubes but the results are consistent. Any idea where else to look? Thanks in advance for any suggestions.
Bryan
Bryan
