1964 B-15 Ampeg
I'm getting further with this amp and still finding problems. After putting in new tubes and testing the caps, all tested fine 25M resistance to chassis, I fired up the amp. It sounded great, no hum, hiss or crackling. I played it for about 10 minutes, shut it down, plugged back in, hit power then flipped the standby switch after warm-up. The gz34 arched internally then the fuse blew. I removed the rectifier, placed in a new fuse, did the start-up and the fuse was fine. I should suspect a bad tube or filter caps? The output tubes could be bad too, but would that make the rectifier arch internally?
Thanks!!
Thanks!!
