I have a fender Bassman 70 Everything seems to work just fine, except the extension speaker output? nothing comes out when i plug into it? Can you help?
Fender Bassman 70
Originally posted by ICOLT45 View PostI have a fender Bassman 70 Everything seems to work just fine, except the extension speaker output? nothing comes out when i plug into it? Can you help?
With nothing plugged in, the output is shorted to ground.
You can not use the other, aux extension "mono/unswitched jack, which only has two lugs, without having an open 1/4" phone plug inserted into the normal used speaker jack, thusly opening it's shorting switch.
Pretty wordy, huh?
