Black face deluxe reverb has a few issues I'm trying to eliminate. I found one problem I was having with the amp popping and squeeling which was elimiated when I removed the V1 preamp tube for CH1 but it happens when I wiggle any tube in that socket. I'm not retensioning it though. I just pulled the 12ax7 and going to replace the 1" socket and tube when they come in. This could somehow play into the problem I'm asking about so I wanted to explain.
Main issue I'm asking about is when I switch the amp on it seems fine right now except for more hum in the overall sound than I'd like to hear. And when I turn the stdby switch off I get a distinct quick and instant pop or snap in the sound. Nothing you'd really worry about except I know this amp has some issues and this might tie in.
I ordered this as a brand new BFDR clone from an amp builder that sells on Ebay and got great ratings on Harmony Central as his auction pointed me to. Unfortunately his workmanship has a lot to be desired. It's a mojo kit based amp with upgraded parts like all mercury trannys, JJ tubes which I'm beginning to loathe with a passion (another story) and it has nice sprague caps and mallory tone caps, carbon film resistors and some okay but pretty sloppy lead dress through out.
I think I'm still fighting a few issues and Lord knows I've been through every solder joint and connection of the whole amp and corrected at least 20-30 little items. I cannot see how this amp still has problems but any instinct and experience some of you gurus out there can pass on to a newbie I'd appreciate.
By the way the only way Ibe capable of checking or setting bias is a crude way with a scope and signal generator and just slightly eliminating the crossover. I dont have the other tools like most of you do. I also have an excellent multimeter and basic tools.
Thanks again for any ideas,
PB
PB
