I made the mistake of putting my little home built amp in an isolation box (with no ventilation) for too long while recording. It got very hot, as you might imagine. Right before turning if off for the night it started to hum very loudly. I have not had a chance to look at it yet - and I didn't even check to see if it still actually works (i.e. I didn't play the guitar through it before turning it off).
Is there anywhere in particular I should start looking for the cause? My assumption (and hope) is that the solder heated up and I simply have a grounding short in the power section, but what else could cause this amp to amplify a large amount of hum?
Thanks in advance.
Greg
Thanks in advance.
Greg
