It was just a matter of time. I was experimenting with the tone stack, maybe a bit too much...
Right after swapping some resistors & the bright cap and treble cap I realized the treble control was working funny (it was lowering treble as you turned it up). I tried flipping the bright cap around to check if I just oriented it wrong, and then tried other caps to see if it was defective. By then the problem had gotten worse. Neither the treble or bass controls on the vibrato channel are working at all at this point. They controls work on the normal channel ,but both channels are noisy (I have the normal channel routed to the reverb/vibrato). Something is seriously wrong & I don't know where to start! I've already checked the tubes, solder connections and looked for blown resistors. I have a feeling it may be a shorted resisitor/cap, but I don't know which one!
Is there a way to test the parts while still in the circut?
I am such an idiot!
Rick
I am such an idiot!
Rick
