I have aquired an old valve amp chassis that uses three preamp tubes and two el84 output tubes, just a basic 10 watt amp. But, the output transformer is confusing.
it has a centre tapped primary, sweet as. but, the secondary has 9 taps! the only labeling on the taps are the numbers 1-9.
What pair of taps should i use for a given impedance? do i just see what sounds best, or do i try to find a pair that have a similar dc resistance to the total speaker load?
