Hi all,am new to this,greetings from Devon in England.Problem is with a Badcat Hotcat100 head that is redplating and burning out el34,s at an alarming rate.Being class A,cathode biased ive worked out the tube power dissipation is being well exceeded for this to occur.This amp is used on Half-power setting into a 16ohm cab.
So far it has new power supply Caps including cathodes;new octal valve bases;and replaced PI coupling caps,all cathode resistors(270ohm) measure fine as do screen grid(1kohm) and grid resistors(10kohm).The voltages measured for 230vac mains in uk are as follows:
plates-pin3= 432v; screen grids-pin4= 405v; cathode resistor drop= 26v
screen grid resistor drop= 5v; o/p tx centre tap= 435v; after choke= 425v
PI HT= 405v
Are these PSU voltages too high?Plates especially?Can anyone throw some light here,anyone had Badcat100 problems like this.All help gratefully received.I'm stumped.
PI HT= 405v
