Hello,
I posted a while back bout this amp. I had decided to pass on the repair but now find myself digging through it trying to find the problem. I've actually gotten it to make some sound which is a start... however it quicky shuts down and a resistor goes up in smoke. The resistor is R27. I tested the speaker and it works. All of the output transistors measure differently in the circuit when I do the transistor diode test... I'm assuming that means that they need to be replaced, unless maybe they need to be tested out of circuit? Any direction on the repair would be oh so appreciated.
