Hi guys,i have a marshall valvestate 8080,one night we were jamming and could smell something burning,their were 5 amps going at the same time so really did check out which one it was coming from,there was'nt any smoke it was just a faint electrical burning smell.So about after the 2 or 3 jams,i had no volume well very little on the O/D channel on my valvestate.I knew it probably was'nt the pre-amp tube,but i bought a new one anyway and installed it.Looking at the board i saw the problem,on the front of the board right under 2 resistors or capacitors,not sure what they are[newb-here] was burn marks.Is this something i should attempt to try and fix myself or bring in into a shop?
I should also mention the clean channel sounds fine,the o/d channel has very low volume,at one point it was almost no volume,but after replacing the pre-amp it has gained some volume,hum?Any thoughts?Thanks guys.
