hi i have just acquired an early 90's model 8100 Marshall Valvestate Amplifier.
It's a solid state, 100 watt (4 ohm out) guitar amp. Made in the UK.
I plugged it to test it, and it produces a ridiculously low volume re-production of whatever signal is being fed to it, guitar, keyboard, but it's almost inaudible over the high frequency squelch it also emits.
If you are, or know an engineer/tech, it's most likely an easy enough problem to fix, as these things are as straight forward to work on as a lego castle. Apparently....
any help would be apreciated as would a referral to a good trustworthy tech in my local area (Central Coast NSW Australia) in the case that i cant fix/meddle with it myself.
I have a basic knowledge of circuitry but am unsure of certain variables regarding voltage i/o and the like and therefore would prefer to pay someone if it is a problem that i in my limited techness can handle.
Thanks for your time.
