Loud Sqeeel When Turning Amp Off
  • Loud Sqeeel When Turning Amp Off
    The 59 Marshall Splawn that I accuried occasionally make a high pitch squeel when turning the Mains off. Sometimes it clicks pretty loud when turning the standby off. Of course I turn the standby off first.....any thoughts.
    It's a badly designed modification to the amp that's causing the problems.
      How could you possibly know that Mikey? Are you a member of the Psychic Friends network?
        Ok when all else fails e-mail Splawn...They said that the effects loop button when activated will cause that and no problem with the amp........TA DAAA
          no, I'm a member of fixed hundreds of tube amps for 34 years network.
          when you said "splawn" you were talking about the badly designed modification network.
          casibom betturkey
