Blown OT??
    why's that Bruce? It shorts out and saves the OT in the unfortunate event that the speaker gets disconnected?
      Bruce what does this do? Will present some sort of short to ground or "backup" resistance if the speaker is disconnected?
      Final note: I checked out the xformer and it measured ok after disconnecting the secondary from the speaker jack. I did however find that 2 primary leads on it were a bit melted and must've shorted! I could not see what they melted from but it looked from the shape of the mark on the leads to be a wire or possibly a socket pin? Anywho I rewired things and used some lock-ties to keep those wired isolated from any potentially hot parts. The OT is fine and amp is rockin'.
        A very common reason for melted wire insulation is someone touching it with their soldering iron.
        casinolevant levant casino
