My Ampeg SVP-1500 is protecting in 4 ohm bridged.
  • My Ampeg SVP-1500 is protecting in 4 ohm bridged.
    Hey there, I'm calling from Denamark. I'm a happy owner of an Ampeg setup: SVP-PRO (serialnr.TPPWH90004) + SVT810E (serialnr. D9ZDR50050) and one Ampeg SVP1500 (Serialnr. ABYWI60015).
    However since I've bougt my SVT-810E I have got a serious problem vith my SVP1500. In the owners manual ampeg say that I can bridge my Ampeg SVP1500 in mono mode in 4 ohm, and that would be perfect for my wonderful Ameg SVP810E in mono mode, but it is not working at all. When I try it, my SVP1500 got dropout and it is protecting after 1minute. It's so warm i can put an egg on it at eat it afterwards. The air fan cooling is working ok.
    What can I do to get rid of this wery serious problem for me and my Ampeg rig.
    Have a nice day!
    Are you sure that's not an SVP 1600 ? You may have it hooked up incorrectly and is the switch set to Mono Bridged ? The speakon should be +1 positive and +2 negative to cab +1 positive and -1 negative. You should be using 12 gauge speaker cable. Sounds like something is shorted are you load is shorted.
    KB
      Most amps (including big beefy PA types) get unhappy running bridged into 4 ohms, regardless of the claims of the manufacturers. It is roughly the equivalent of running each side into a 2 ohm load.
      Also, though I'm not familiar with your particular amp, Ampeg usually uses a temperature-sensitive fan speed circuit and is notorious for underestimating the cooling needs of the amp. Perhaps replacing the little DC fan with a high-CFM AC type wired directly to the mains and running at full speed would help, but I still think the bottom line is 4-ohm bridge-mono operation is a hardship on the amp and will cause premature failure of the output devices.
      Maybe you need an additional 810 cab for stereo operation!
      Mark
        Mark
        And here I was about to suggest wiring the cab as a dual-4x10.
          Hi there! Thank for your answer!
          I think my problem is that my Ampeg SVP1500 - yes it is a SVP1500 with correct cabels - can't use Bridge mode in 4 ohm - it is correct Mark Black. I think I will sell my SVP1500 and buy me a new Ampeg SVT-CL. That should be a good setup - SVT810E and SVT-CL! It's far to heavy with 2 SVT810E, then I need at new car too!!!
          casinolevant levant casino
