Looking for help
.........I've got a JTM60 that has a weird problem. I had it serviced, new tubes, bias , Transformer, output PCB. When I got it back it would work for a while then start to output low almost no sound then come back and then go out. I took it back to him and after having for 3 months says he can't figure it out. I took it apart and cleaned it up and checked the caps and looked for cold solder joints. When the chassis is out of the cab it worked fine. When I put it back in the problem came back. I did this a few times with the same result. For kicks I put a jumper cable across the series effect loop and it seems to work. My question is what do look for now or should I just keep the jumper in place. I'd like to solve it so I can sell it! Any ideas welcome. Thanks.
