A friend of mine ordered some NOS 7027As on the net and put them in his VT-22. Next thing he knew there's smoke coming from the chassis.
Turns out on one of the NOS tubes the big plastic socket pin in the middle of the base was broken off. So I guess he put the tube in the wrong way (because of the missing alignment notch).
Ouch! Big short...
I opened up the amp, but no burnt resistors, no popped fuses, no visible signs of burns or melting or cracking.
I put in some new 7027As. Checked the OT, seems fine. Checked the voltages, seem fine. No sound on the speakers, though. Only some crackling when I used the probes to check the voltages.
No signal on the pre-amp out. I used the power-amp in and there's the signal on the speakers, but very, very low volume and it's starting to distort when I crank the signal. I haven't replaced the preamp tubes and the PI yet, cause they're somewhat more exotic (I haven't got a spare 6AN8A)...
Any ideas where to look before I start checking every single component in there?
Thanks,
marc
Ouch! Big short...
Thanks,
marc
