Hello I am Tim and I am an experimental guitarist from Manchester, UK. I have recently bought a used Laney LC15 which I love for its sound, but is not working reliably. Was wondering if you people could help me with advice on repairs and spares?
The problem is that the volume abruptly goes down, or cuts out completely. This can happen at any time but usually occurs when unplugging and reconnecting the guitar, or when plugging other amps in to the mains.
The volume usually comes back on if you fiddle with the 'Gain' knob, This led me to suspect that the pot is corroded or dirty. I partly dismantled the amp and sprayed Switch Cleaner and then Lubricant onto the Gain pot. That seemed to improve things, but the problem still occurs. I have recently noticed a similar issue happening with the Bass pot as well.
So the questions Id like to ask are:
1) Could this actually be a valve problem not the pots?
2) Where to get replacement pots for this amp?
3) How to get the plastic knobs off the pots without damaging them?
Hope somebody out there can help. Thank you.
Tim
Tim
