I have a Valve Junior that I am modding a bit, and it's the one with the 7.5K ohm primary OT. I am wondering if changing the 4 ohm speaker I have in there to the 8 ohm tap will be a problem. It'll bring the primary impedance down to around 3.7K ohm. Is that too low? I know ideal is around 5.5K ohm.
EL84 Acceptible load range (Single Ended operation)
Originally posted by trevorus View PostI have a Valve Junior that I am modding a bit, and it's the one with the 7.5K ohm primary OT. I am wondering if changing the 4 ohm speaker I have in there to the 8 ohm tap will be a problem. It'll bring the primary impedance down to around 3.7K ohm. Is that too low? I know ideal is around 5.5K ohm.
To halve the impedence you'd have to go the other way, plug a 4 ohm speaker into the 8 ohm tap or an 8 ohm speaker into the 16 ohm tap.
Do you have one of the earlier OTs with only one impedence on the secondary?
Originally posted by Chuck_Farlee View PostIf your OT measures 7.5K:4 ohms and you plug in an 8 ohm speaker, you double the impedence to 15K, not halve it.
I must have mis-spoke. Plugging in 4 ohm load into the 8 ohm tap. I have a 2 impedance secondary. It's a rebuilt combo. 4 and 8 ohms.
So, anyone know if ~3.5K ohms of impedance on the primary for an EL84 is safe? I've been running it, because if the amp fries, I'll just rebuild it, and it sounds better like that. I just don't want to HAVE to rebuild it. (AKA re-install the magic smoke...)
The Mullard data sheet on the "franks" page has data on using a 4.5k SE OT, which doesn't give less power than 5.5K, but a rise in overall distortion, tilted mainly towards second harmonic. I suspect this is why it sounds better with a reduced load.
If maximum power transfer was stable from 4.5 to 5.5k, then a reduction to 3.5k doesn't seem that drastic, unless its accompanied by excessive HT voltage, ie over 300V.
This is all theoretical.
Someone out there is bound to have tried it.
Originally posted by trevorus View PostIt's in a valve junior, and I can't remember what the plate voltages are... It's PT says 260V, so can't be that high.
The PT is rated for 115v on the primary to 260v on the secondary. After rectification, the peak voltage is 366, if you have 115v coming out of your wall. Peak voltage will be more if your wall voltage is as high as mine @126VAC.
chuck
Originally posted by Wakculloch View PostThe person "out there" trying it seems to be you , Mr Trevorus!
