Plate voltage w/ tubes in
  • Plate voltage w/ tubes in
    working on vibrolux reverb and the plate voltage on plates are 440VDC without tubes and a low 365VDC w/ tubes in. this does not seem right to me. The 6L6 in there are brand new JJ.... I know just cause they're new doesn't mean they're good. The amp is also suffering from low headroom and a fair amount of distortion. I have set bias at 35ma, replaced ALL plate resistors throughout the amp, all bypass caps, bias supply diode and filter cap, and all coupling caps. I have not touched filter caps because they test fine for leakage and the VDC on pin3 with no tube seems fine. I have decided to try a different set of tubes. I place one tube in one socket w/ other socket empty, fired up the amp and the voltage was 440VDC for about 3 seconds then blue sparks exploded inside the tube... I shut it down quickly. I put the same tube into the other socket and fired it up. The VDC on the plate fluctuates all over b/t 440VDC and 380VDC. so then assuming that this tube is now bad I put a new one in the second socket and it was fine... 440VDC. I then added another new tube to socket 1 and the amp makes a HORRIBLE farting noise. I went to pull out socket 1's tube and the socket came out of the chassis with it!!!! Could this be the problem? I know this IS a problem, but would a loose/bad tube socket cause fluctuating voltages and farting noises? Does this mean the socket is arcing inside cause I don't see anything as far as burn marks go.
    Well,
    let's say the grid pin (5) decided to let loose...then the tube is drawing max current...not good. If for some reason the grid goes positive, it starts drawing current & that's not good for a grid.
    similarly, if the screen plate pin gives out, then the screen grid tries to act like the plate & draw all the current. It too, will glow & eventually crap-out.
    Just running the amp with one tube shouldn't cause that tube to blow at low volume, but still not a great idea.
    Once a tube shoots sparks inside, you might as well condsider it shorted & dangerous to put back in.
    Sounds to me like your lack of headroom could very well have been a result of bad socket connections. Replace those puppies.
    p.s. it would be wise to go back & check for certain that you have all the correct values ie; you have the color code correct. It's easy to replace a 100K (Yel/purp/yel) with a 10K (yel/purp/or) & so on, esp if it's your first time.
    When you do something like replace all the plate resistors or all of anything in a device, it's always good to do them one at a time. It's very easy to goof up if you cut them all out first & then attempt to replace them.
    Most techs will agree that the most difficult problems to solve are the ones you caused yourself, cause you don't always think to go back & check your own work sometimes. Us older guys dont' do that quite as much as we did in the early days...I'm thinkin' ;-]
    I don't know how you did it, but
    glen
      Oh man...It's too late in the day for me to be thinking. I got those color codes wrong!! See how easy it is!!
      Sorry....Yel/Purp/yel = 470K yel/purp/or = 47K I'm going home now....ZZZzzzzzz glen
        Thanks Glen,
        Yeah makes total sense w/ the grid and screen not being connected and the tube operating at maximum... definitely not good. I'll replace those tube sockets... thanks! I will also double check those plate resistors and whatnot, never a bad idea to double check the work I've done... as I'm constantly being reminded.
