Hello,
I am fixing a 70's Magnavox B15 for a friend of mine. I replaced the filter caps and some of the tubes. This model uses 3 6l7gt's, 2 6L6's, and a GZ34.
I am getting a slow beating, motorboating oscillation at high volumes with the bass all the way up.
I Switched 1st filter cap from 30U 600v, to 2 20U 600v caps, so now 40U at 600v. I replaced the other filter caps as well with a new cap can wired the same way.
I switched out the diode and cap on the bias supply. I think this, combined with the tubes was contributing to the hum.
I have one new 6L7gt, and tested the others with my emissions tester( all i have) I ended up using the new tube in the phase inverter/driver position, figuring that if one of the others was bad, then i'de have one working channel.
--So it sounds really nice, just wondering about ways to tame the oscillations
Ideas
Ian
------I am noticing that now my voltages are a bit higher.
Ideas
Ian
