location of 3rd wire
  • location of 3rd wire
    does anyone know where the 3rd wire goes on a mesa nomad 45 Ac mains switch?
    1)goes to the fuse
    2)goes to the pilot light
    3) goes????
    thanks in advance for any help!
    -aj
    "Success!!! Only three leftover parts!!!" -Mr. Flavinger after putting his daughters bass back together
    Are you talking about the ground wire?If so it is best to attach it to a PT mounting lug.
      Some rocker switches have a separate pin for the lamp inside. See the spec sheet or data sheet for the switch itself, Mesa didn't make the switch, Carling or somebody did.
        thanks for the help! but where would that be??
          Wait, there is a safety issue here. EXACTLY what wire are you talking about?
          I am talking about an extra connection on the power switch itself beyond the normal two wires.
          Stokes is talking about the third wire in the power cord.
          If you connect the wrong thing to chassis, you can have serious problems.
          How about a photo?
            How about a photo?
            its not a rocker switch its a 2 lead toggle switch but it was 3 wires coming off it...
            and ill try to get a photo up tomorrow.. im not near the amp right now
              this may get you in the right direction. It's from a Mesa 50 Cal.
                maybe its just my computer but the picture would not show
                email to me if you can
                ajisjesus@gmail.com
                  Must be your computer or ISP, his photo was there in his post and also within the quote box in your post.
                  Perhaps the hot comes in vua one wire, and after the switch it goes to the rest of the circuit AND to the pilot light.
                    I sent the pic to your email address aj.
                    Gary
                      Thanks for the pic! i will see if it works out!
                      I took a pic of my amp it wasnt very good quality so I highlighted each wire
                      [IMG]C:\Documents and Settings\WHS Electronics\My Documents\My Pictures[/IMG]
                      RED w/ circle (the wire in question)
                      GREEN - from lead 1 to the pilot light
                      PINK - from lead 1 of power plug to pilot light
                      PURPLE - from lead 2 to fuse
                      because of my isp i cant tell if you guys can or cant see the pic but i'm going to try and post it anyway... if that doesnt work i'll email it to whoever wants it
