Any ideas?
quickest/easiest way to test zeners?
Zener diodes can be tested for open and short with an ohmmeter the same way that you test regular diodes. Testing for operating voltage needs to be done in a circuit.
One of my first repairs as a tech was a MuTron power supply that used two 9 volt zeners. If I recall correctly, testing it in the circuit showed some unusual readings, but out of the circuit showed it was open.
The same customer also brought in a MuTron Phasor, which had problems with the LFO. It's one of the coolest tones ever!See the birth of a 2-watt tube guitar amp - the "Dyno Tweed"
http://www.naturdoctor.com/Chapters/Amps/DynoTweed.html
Yep.
First, they are diodes after all, so they should test OK forward and open backwards on a meter like any other. If a 1N4007 shows maybe .470 volt on a diode test expect a zener to read a little higher, like .6 or .7v. But still acting like a diode. This sorts out the shorted and open ones. Then like KB and PRNDL said, they must be in a live circuit to test their zener voltages.
If you have a bunch and wanted to make sure they are OK, you could rig up a tester easily enough. Start with a voltage source, either a bench supply or steal some voltage from an existing product. COnnect it to the zener to reverse bias the zener, and IMPORTANT you need a resistor in series to limit current.
SInce zeners require a certain minimal current to "zene," make the resistor a pot. Now dial down until the thing turns on and then the voltage should be pretty stable across the part. Don't turn the pot down too low and overcirrent the zener.Education is what you're left with after you have forgotten what you have learned.
