First off, I don't know what I'm doing. I can be safe inside an amp, and learn easily, but I don't possess any knowledge of my own about amps. That being said:
So I bought a Kalamazoo Model One from a guy who said it was humming real bad. I installed a three-wire power cord. Then I decided to do a cap job. Going from what I read on a harp site (I'm a harp player), for the power supply filter caps, I went with 20uF for all three. After that, the amp sounded great! Then I decided to change all the other caps, and while at it, I upped their values all to .1uF from .0047, .01, and .01, respectively. Then when I turned it on (with the chassis open), I saw what looked like a lightning bolt behind clouds come from the fuse lug that I had connected to the hot mains wire. I immediately turned it off. No blown fuse or any damage that I could see, and no smoke or smell.
But now when I turn it on, I get nearly zero volume at full crank. The preamp tube looks fine, but I think the power tube and rectifier (tube) are both bad. I put a new power tube and tube rectifier in it, and while the power tube survived this test, the rectifier blew immediately. I verified that it no longer works by putting it back in the amp I got it from, and it wasn't working.
So what did I do? I can afford to take it to a tech, but I really love doing stuff on my own, and I have other amps I can play in the meantime. So I'm hoping for a diagnosis that I can use to remedy this problem on my own. I'm not sure what other info is pertinent, so please, ask me questions.
Thanks in advance!
Thanks in advance!
