Hi I have built a JCM800 clone with an original OT, four EL34, 100W and I have an issue with the presence control, if I put the control on a low value it make some loud noises. It`s worse if I turn up the master volume control. it don`t happen if I cut the Feedback wire. so I suspect is a weird problem of the power amp and the NFB.
here is a sample of the noise.
http://www.soundclick.com/fireland
I also have some doubts about the wiring of the presence pot. in this layout there is DC through the pot , not like in the schematic.
http://www.dreamtone.org/pdf/NEW2204...mDreamTone.pdf
also in this one
http://www.sonicdeli.com/ThunderTwea...fuellayout.htm
I have checked voltages and it seems to be ok, unfortunately my oscilloscope only can measure AC.
someone had any similar problem or have any idea of what more I must check?
cheers
Rafael
also in this one
cheers
Rafael
