Triode connection of pentodes usually means that the screen is linked to the plate, either directly or through a current limiting resistor.
Taking the screen supply from the same node as the plate supply still counts as a pentode configuration, not triode. With a big reservoir cap it might be fine, though stock it might be prone to ghost notes (ripple modulating the signal) at high signal levels.
However it's configured (UL / pentode / triode), those screens will be at the plate dc level around 500V, well over the max 6L6GC spec.
As I understand it, those 70s silverface Fenders were designed around the Sylvania STR387 6L6GC, a special uprated 6L6GC. Paul Rivera said something like 'that tube was so good it should have been given a different designation'. I think that the JJ 6L6GC has a similar rating to the STR387, though the consistancy might not be up to Sylvania's standard!
Hope that helps - Peter.
