I built a 5E3X2 not too long ago... love it. It is a great sounding amp. I recently decided that the low end was too much and I was getting that farty speaker thing going on. I reduced the first stage coupling cap to .047, both bypass caps on preamp tube and gain tube to 10uf instead of stock 25uf, and both phase inverter coupling caps to .047 instead of .1. I also changed the screen dropping resistor in the power supply from the 2.7k to 5k, and in doing so I also changed the C+ dropping resistor to 47k to keep the ratio constant.
After these mods the low end is great, however I now have reduced high end...?? I don't understand how that happened... could the power supply resistor changes cause this?
