I've got an old Orange GRO100 on my bench. Brought in with the complaint it's blowing the B+ fuse (1 amp fast blow). Owner was playing amp for half hour and B+ fuse blew. He replaced the fuse and it immeadiatly blew.
I pulled the tubes, popped in a new fuse and it held when I turned the amp on.
I put the tubes back in, one by one and turned the amp on each time. Each time the fuse held. Finally with all four tubes in, I played the amp for a while.
I left the amp on for around two hours while two nights in a row while I worked on other stuff. The fuse held the whole time. I actually used a 1/2 amp fuse as I didn't have any 1 amp fuses on hand. The tubes were fairly old so I advised the customer to replace them. I installed new tubes, biased them to around 70% plate dissapation. Also installed correct 1 amp fuse. Turned the amp off, put the amp back in it's chassis and turned it back on to let it burn in for awhile.
And the B+ fuse blew. Just a second or so after I flipped the on switch. I put another fuse in and flipped the on switch several times.
The fuse held each time. I did notice that there was as momentary hum that went away after the amp was on for a couple of seconds. I also heard that just before the B+ fuse blew.
I plan on letting the amp burn in for another couple of hours and/or see if I can get it to blow by turning it off and on.
Other than that I'm not sure what the next logical step is. I suppose the new set of tubes could have a problem, or maybe the 1 amp fuse was defective but, I'm thinking that there is possibly an intermitant problem that is causing the fuse to blow.
Any guidance is much appreaciated.
