Hello forumites,
I've got an annoying ghost note in my GDS kit-derived 18 watt. I hear it as a faint tone about 120 Hz below what I'm actually playing, mainly on notes played on the 2nd and 3rd strings and with the amp dimed.
Because of the ~120 Hz difference in the notes, I suspect power supply ripple is getting through in high gain situations.
Things I have tried:
Changing to a different speaker cab (it's not cone cry)
Removing the attenuator from the equation
swapping out preamp, PI, and power tubes
Replacing all power caps
Upping the 16 uF (last) power cap to 22 uF, then 44 uF
Changing the EL84 cathode cap from 100 uF down to 50 uF
None of these has exorcised the ghost note.
http://www.broad.mit.edu/~robriley/music/ghostnote1.mp3
I'm thinking about changing the rectifier next.
Ideas?
Ideas?
