Any body else make this stupid mistake? I have an old power transformer from a phonograph and a Weber Princton OT wired up with a 5e3 style PI and cathode biased. It worked at first power up but when I went to check the voltages on the 6v6 tubes I found I had 300+ volts on pin 5. I discovered that I had wired pins 4 and 5 backwards
I played it like that for 20 or 30 minutes. Is that hard on the tubes? Did I do any damage?
When I get that rewired how do I determine the proper value of cathode resistor? I have about 327v on the plates. I'm using a 250 ohm for the moment.
Thanks,
David
![EEK!](https://music-electronics-forum.com/core/images/smilies/eek.png)
Thanks,
David
