Hi-
I've got a solid state Peavey TNT 115-BW that I've had since about 1992. When I play my bass through the amp it has Crackling noise through the speaker as if the input cord was bad.
I took the amp out of the cabinet and the speaker to make sure connections were good and fired it up with NO problems. It work great! Put it back in the cabinet and the same problem occured.
This being a bass amp I'm thinking the vibration from the speaker is causing the problem but not sure what to check. Any help would be great!
