Hello folks,
I am working on a very tired V-40 that has a weird standby switch issue. When the unit is in standby, the B+ from the bridge into the unit is still present & the amp buzzes badly. In this model, the standby switch switches the ground to the bridge rect instead of the usual positive output. I've worked on many of these amps & know this arrangement obviously works.
http://www.drtube.com/schematics/ampeg/vt40pwr-jp.gif
I've tried to isolate any possible other path to ground around the switch & I cannot find one. there is no low resistance from the bridge side of the stby switch to ground (chassis) that I can find. BTW, the entire ground side of the power supply terminates to the chassis at the input jacks.
The diode in line with the standby switch I'm guessing is for isolation to allow the neon stby light to function properly.
When the unit is in stby, the B+ voltage with respect to chassis ground remains about at what it is with the unit in operate mode. I wish I had another of these amps to do some A-B comparison.
BTW, this amp had some water damage on the edge of the main pcb, but I've cleaned all that off & am fairly confident that there are not paths to ground there...esp a high current one!
Anyone else ever have an issue like this? thanx, glen
