This LM3886 11-pin amp chip is in a Tech21 Power Engine 60. The amp came to me because another tech had fitted the chip and failed to get the amp to make a sound. Given what I write below I think it's the right chip or should work anyway. But I too have so far failed to get an output despite fitting a new chip.
So my question is, why might a LM3886 not amplify despite the following conditions:
Pin 1 +32v
Pin 4 -32v
Pin 7 grounded
Pin 10 healthy input signal
Pin 3 goes to the speaker
- Hmm? Even if the LM3886 was the wrong chip to fit I would have thought it would be ok with the above connections. But Pin 3 flatlines.
Pin 8, the mute pin, has a few volts on it. There is no connection to that pin.
I don't have a schematic, I'm afraid. Any possibilities springing to mind?
Pin 1 +32v
Pin 4 -32v
Pin 7 grounded
