A customer has a 6505 that's been in twice with similar issues. First it was the output jacks were intermittent. I replaced them with new jacks and sent him on his way. He brings it back, says that it worked fine for a week and then had the same problem. I put it on the bench and it's oscillating badly, so I remove the preamp tube cover, which is bent quite a bit (dropped amp???), and pull some 12AX7's to isolate the problem. After swapping tubes around, and cleaning/re-tensioning tube sockets, the problem is gone, with the original tubes back in place. New output jacks seemed to be fine. I ran the amp on and off for a couple of days and could not get the problems to re-occur. He takes the amp again, and calls me from the road again. It worked fine for a week and then started to act up again. He's pissed off, and I don't blame him. I don't trust the molex connectors in those amps, and this guys on a van tour, with the head probably getting tossed about a bit. Are these amps that touchy/unreliable?
How do I tour-proof this head? Switchcraft output jacks? Hardwire all of the Molex connectors? I really want to touch up all of the connector and pot solder joints when it comes in again. I should have done that the last time, but did not. My f-up. Aargh!
