I just picked up an Ampeg b-100 bass amp, circa 1976 or so. I purchased it with a known problem: It sounds like it has a distortion pedal plugged into it. According to the guy I bought it from it's NOT a speaker problem. He says he tried 2 other speakers and had the same results. I believe him as the first thing I did when I got the amp home was pull it apart and I could see that the speaker had been removed. Also the speaker wasn't hooked up as he'd been trying others. Unfortunately, I don't have another speaker to test it out. While I had everything pulled out I did a visual inspection of the board to see if there were any obvious things wrong. Everything looked ok and there were no obviously blown capacitors or goo or anything on the board. I then hooked it up and it played it for the first time. It really sounds like I've got an overdrive pedal plugged into it.
So my question: Other than a blown speaker, what could cause this?
Thanks in advance for the advice.
