I have about 124v at the wall outlet in my area. I have a 1:1 isolation transformer between a amplifier and the wall. Even thought the transformer is 1:1 the voltage it is putting out is closer to 130. Any ideas why this is the case? The transformer is rated at 115v (see picture). Could that be the reason? I thought the the idea of 1:1 is that the windings are identical on both sides, so what goes in one side comes out the same one the other. If the windings are not identical for some reason, could I reverse the input side and output side to reverse the voltage imbalance (high at the wall, lower at the amp).
I need the transformer for safety, but it is making my already high outlet voltage even higher.
Thanks.
Thanks.
