Marshall AVT150HX Schematic
I quit displaying my email, too many emails.
This should be what you want, the rest of the amp should be the same as the 150.Attached FilesEducation is what you're left with after you have forgotten what you have learned.
Problems with the AVT150hx
Yes it could be the valves. Try pulling them all out and see if it still blows the fuse. If it doesn't then something is wrong with either the tube(s) or biasing circuitry, both, or even something else related. When you put them back in, do it one at a time to see if you can narrow down the problem to one tube or stage.
I was in Guitar Center (GR, MI) and they had one of these amps that they were selling cheap because it wouldn't power up. I heard mention that it was the main power transformer. Due to the cost of the part and what they wanted for it; it was just as expensive to buy one new or off ebay in working condition so I never messed with it.
Good luck!
avt150hx blowing fuses
Ok here is where im @ i went thru several fuses backtraking the wrong way..ends up if i unplug the primary leads to x-former no fuse blows..im reading 1.7 ohms on primary..till i fix that it doesnt matter what downstream is..any ideas? i dont have a megger..Im sad i got myself into this situation..this is for an older guy in maintenance dept..his sons have a band and he thinks i can fix anything..yes i have a diploma in electronic's/computers but that was my core for associates in robotic's / automation..the 1.7 ohms doesnt suprise me as a primary ohmage but i may be wrong..and the only fuses i could find close at work happened to be 3.5 amp@125 volt..but with secondary unplugged..it shoulda been fine..im thinking primary is faulty..doesnt seem right though..doeasnt show open or anything to ground..not even in the meg's. HELP please
The power transformer? If the secondary is not shorted to the primary, and neither is shorted to the frame, that is about it for your meter. Two turns could be shorted together and your meter couldn;t tell the difference.
RG has a nifty simple transformer tester on his Geofex web site.
But really, disconnect ALL the secondary wires - 2 secondaries, 6 wires. Now does it pop fuses? Disconnecting the primary leads will almost always stop an amp from blowing fuses, after all that disconnects the ENTIRE circuit.
Look up "light bulb limiter" make one and use it. Or use a variac and ammeter.
Are the secondary wires on the right posts? If it blows fuses with NO secondary wire connected, then yes, I suspect the transformer. But it really is the lowest thing on the list.
When an amp blows fuses, the list starts about like this:
shorted output devices
shorted main rectifiers
shorted low voltage rectifiers.
main power rail shorted to ground
shorted filter cap
mis-wiringEducation is what you're left with after you have forgotten what you have learned.
just got home from wrk
Yes all secondary wires disconnected and it blows fuse..I dont know why i didnt ohm the secondary's out last night..I think thats the problem..they are both reading dead short to .1 ohm..they are not reading to each other but both the 18 and 32v secondaries show no resistance to there assigned common. I blame the BEER =p.
