Hi again -
Anybody have (and care to share) a schematic for the power section of an Ashdown EVO II 500 bass amp?
Or an idea where to look for the cause of my remaining problem:
The amp came in with shorted output & driver transistors, and showed signs of having been worked on before. I replaced all output & driver transistors and checked all the other components in the output section.
The amp now fires up & passes signal but has an anomaly on the negative peaks at onset of clipping which I guess I would characterize as "latch-up". Instead of gracefully coming out of clip and following the sine wave signal back toward zero volts the waveform continues at the negative rail voltage briefly then snaps to continue the sine wave forming an extended 90 degree "corner" as seen on the scope. The positive peaks seem to act normally and as I would expect at onset of clipping.
It's just another thing I haven't seen before so I would welcome ideas or commentary from someone who has...
Thanks!
Mark
Thanks!
Mark
