Trac Elliot Speed Twin Output Tranny Specs and Replacement ?
  • Trac Elliot Speed Twin Output Tranny Specs and Replacement ?
    I have a Trace Elliot Speed Twin 50 watt combo that I "think" needs an output transformer. It's symptoms included somewhat reduced output for a while, then really bad sounding breaking bottle like distortion on real loud notes, then almost no output altogether Have to crank all controls wide open then you just barely head output)
    I have done the following:
    -Replaced all tubes and biased
    -Checked all power supply voltages
    -Replaced all High Voltage caps
    -Checked coupling caps between amp stages
    -Checked value of all pertinent power amp resistors.
    -Verified that preamp runs fine by using the effects loop output into the poweramp of another amplifier.
    -Tried a different speaker
    A also performed some DC resistance measurements on the output transformer, which I know are of limited use, but they are:
    Primary:
    One end to center tap:37.5 ohms
    Other end to center tap: 60 ohms
    End to End:67 ohms
    Shouldn't the overall equal the sum of the two parts ? Is this suspect ?
    Output side:
    Common to 16 ohm tap: 0.1 ohm
    Common to 8 ohm tap: 0.6 ohms
    Common to r ohm tap: 0.4 ohms
    Does ANYONE know where I can get a spec to identify a replacement ? There are no markings on the transformer, and no part number listed in the service manual. Any assistance would be greatly appreciated.
