Ampeg V4-b, bad 6k11 stage...
  • Ampeg V4-b, bad 6k11 stage...
    I've been working for a while trying to find the issue with an ampeg v4-b amplifier a customer of mine brought in for repair.
    Now bear with me, this is kind of a wordy and involved question.
    This amplifier has a constant pink noise type sound with crackling and the signal is very weak and distorted.
    I signal traced the bad sound to the pin 2 of the 6k11 (the output of the first gain stage the 6k11 produces).
    With the tube removed pins 2, 5, and 10 (where b+ is being fed to the different sections of the tube) show high voltages that coincide with the original ampeg schematic. However when I reinstall the tube pins 2 and 5 (which are fed by resistors) drop dramatically to about 40 volts on pin 2, and 8 volts on pin 5. Pin 10 remains high.
    I tried replacing the 220k and 470k resistors that feed b+ to pins 2 and 5 respectivly, but the same problem. I ordered a 6k11 (philco) tube from CE distributions and had the same problem when installing this tube. Is this an issue of 2 shorted tubes? Is there something else I should be checking for?
    Here is the schematic for anyone to look at.
    http://www.schematicheaven.com/ampegamps/v4bpreamp.pdf
    If anyone has any insight as to what might be going on that would be great!
    Check for DC on the grids?
      Well, pin 10 can ONLY remain high, as it is a cathode follower, so that is no indication of anything. I really don't think you have a shorted tube. Personally, I've never seen a shorted NOS 6K11, only ones that got noisy or plain tired.
      You MIGHT have a bad cathode reistor, but my FIRST suspect would be the .01 coupling cap from section 1-2. If it were shorted, it would drive section 2 into cutoff and upset the DC balance. Lift one end of the cap, plug the tube in, and see if you have your proper DC voltages. You only have a handful of components there, but I'd start with that.
      You might also have a carbonized and/or contaminated tube socket. Take a look at the socket and see if it looks burnt and/or brittle in any areas.
      John R. Frondelli
      "Mediocre is the new 'Good' "
        Right you are about the last stage. I forgot it was a cathode follower when I was writing out all of my voltage findings and trying to visualize what was going wrong.
        The .01 coupling cap was the culprit the whole time! I de-soldered the cap and everything looked peachy, so I put in a brand new cap and the amp sounds wonderful.
        Thank you for your expertise. You must be a valuable tech in your area. And what a learning experience.
        And to the other reply, there was some dc on the grids, but it was a very small voltage and I didn't know it would throw things off as badly as it did. I will check the rest of them and replace any of the remaining coupling caps that are passing dc.
        Thank you for your help!
          Glad I could help. Wanna e-mail my boss and tell him that?
          John R. Frondelli
