Does the noise seem to relate to using the pot? Or did you just clean it for old times' sake? If the pot makes noise, it can be other things than needing cleaning. The pot can be worn out or have cracked solder, so motion triggers noise. Also, if a pot has DC voltage across it, it will be noisy when moved.
Does tapping the amp make noises? That would be a loose connection somewhere. Don;t be shy, give it a solid swat on top.
If it just sits there alone making pops and crackles and grumbling noises, my first suspect is a noisy transistor.
