Hello,
A friend of mine a month ago started having a problem with this FENDER PRINCETON 112 Plus Guitar Amp (manual link):
He said he started to hear a background sound, like 'Ammm' ..
When disassembling the amplifier the wire\piece of the sepaker negative fell (I assume it was not well soldered):
I just put a screw on the piece that connects to the speaker metal:
I check the Board and visually it wasn't bad, I just cleaned it with a cleaning spray (Contact cleaner R-10), i plugged it in and i didn't heard any noise, I assumed that the problem was that 'Ground' connection at the speaker..And returned it to my friend.
He then tested it and the first time it was OK, But the next time he turned it on the background noise appeared again and, coincidentally or not, the 1A fuse blew.
I have now opened it again but honestly, apart from the fuse, everything seems OK.
Bottom of the board:
'Reverb' seems fine, everything makes contact ..
The Big capacitors are fine:
The 4 diodes are OK:
I tested the CR13, CR14, CR26, CR27 too.
The Big white resistors seems fine (have approximate values).
For the two transistors i took them off and i had this readings:
TIP147 (PNP - BCE)
C->B: ~ .567
E->B: ~ .761
C->E: ~ .441 (Here at the beginning I thought that there shouldn't be any reading but, I presume, that being a Darlington is normal)
TIP142 (NPN - BCE)
B->C: ~ .527
B->E: ~ .648
E->C: ~ .418 (The same thing I said above ..)
The speaker is ok, has a resistance of 7R and it works:
http://youtu.be/KAMlXAuWe8U
Now, i put everything in place, i soldered all the joints of the board and clean it with isopropyl alcohol.
I put new thermal paste on the Transistors, should i put more or this is enough? (i didn't took the thermal pads off, just cleaned the superficial old thermal paste and put a new one between transistor and thermal pad.)
Do you think that i can put a new fuse and plug it in or its better to check something else?
Thank you
TIP147 (PNP - BCE)
C->B: ~ .567
E->B: ~ .761
TIP142 (NPN - BCE)
B->C: ~ .527
B->E: ~ .648
Thank you
