I'm working on a 450 with low output and I have a question about the schematic.
My particular unit is making 11 Watts clean before the sine wave at the output starts to look like a triangle. The issue appears to be in the power section since when I drive the power amp via the "access" jack I have the same result. I've replaced every electrolytic in the entire unit except maybe one in the graphic EQ.
I've started going through and measuring voltages and I'm curious where the 27v is coming from at the bottom of Q401 (the differential PNP pair at the input of the power amp. My voltages so far are as follows:
Q401
E: 24.3v
B: 23.4v
C: 3.2v
Q402
E: 24.2v
B: 23.6v
C: 0v
Q403
E: .86v
B: .32v
C: 44.8v
I've pulled Q401 and Q403 out of the circuit and tested them with a Peak tester and both are fine. Obviously something weird is going on with 403 as well.
I've attached the relevant chunk of the circuit from a previous post. A complete schematic is here in this post but for some reason I couldn't get it resized to upload.
https://music-electronics-forum.com/.../page2?t=20743
Thanks!
Q401
E: 24.3v
B: 23.4v
C: 3.2v
Q402
E: 24.2v
B: 23.6v
C: 0v
Q403
E: .86v
B: .32v
C: 44.8v
Thanks!
