Fender Pro 185 need resistor
  • Fender Pro 185 need resistor
    Anybody know where you can get a ceramic/cement .22 ohm 20 watt speaker resistor for the Fender Pro 185?
    You could contact a Fender dealer and ask them to order one, but something that old may no longer be stocked by Fender.
    Did you check Mouser Electronics or Digikey or Allied or MCM or ...
      Mouser sells this, which would work, but would require mounting.
      stock # 284-HS25-0.22
      MCM: http://www.mcmelectronics.com/product/25WD22
      It is 25 watts so check the physical dimensions.
      Parts Express: http://www.partsexpress.com/pe/showd...number=017-.27
      CLose.
      Or stack a couple .47 ohm ones in parallel.
