Early-mid 70s marshall jmp mkII 50w
  • Early-mid 70s marshall jmp mkII 50w
    Need some help with this one, it's a 4 input 50 watt non master head. It's been mucked with before i got it and so I'm restoring it to original. Anyone know where i can find a schematic and or component layout layout for this amp. Found some that are close but not exactly this amp. Thanks in advance.
    Look at the top of the page, in the bar that says FORMS BLOGS ARTICLES...
    Click on the one : Schematic Hell, and look through the MArshalls there.
      Could it be this one perhaps?
      Support for Fender, Marshall, Mesa, VOX and many more. https://jonsnell.co.uk
        Try again ... jmp_pa_50w_1963.pdf
          Is it this one: https://drtube.com/schematics/marshall/1987mk2u.gif
          If not, what is different (other than things that may have been 'mucked' with)
