Guess the value
  • Guess the value
    Ok I’m repairing a carlsbro glx100 the diagrams on line are completely different to the model I’ve got, problem being it’s overheated in the power supply area damaging tracks and component, I’m now down to changing one last component a resistor, heat damaged. It’s on the feed to the power LED
    please see pictures on tester it’s reading 16.5 k ohm
    If you know the voltage feeding the LED, you can choose an appropriate resistor for 10-20mA.
    http://amps.monkeymatic.com
