What tool and solution should i use to clean oxidized preamp tube sockets on my Fender red knob twin tube amp? Should i use a small nylon or plastic brush or should i scrape the rusted pins with a knife?
Cleaning oxidized tube sockets on Fender Red knob twin tube amplifier
I've used the smallest Wiha bladed screwdriver, size 260 1.5 x 40 as well as a Pace P/N 6993-0200, which is normally used to clean the throats of their De-Soldering Iron tips and irons. It has a wide range of cleaning wires, each having a textured metal finish to burnish the insides of the desoldering iron tips and tool throat, but, also work well for burnishing the insides of the tube sockets. I've attached a link to Newark's listing of the item, which also has the data sheet for the cleaning tool, On the larger power tube sockets, pipe cleaners work, dipped in DeOxit.
https://www.newark.com/pace/6993-020...it/dp/70C2397#
- Likes 2
Originally posted by nevetslab View PostI've used the smallest Wiha bladed screwdriver, size 260 1.5 x 40 as well as a Pace P/N 6993-0200, which is normally used to clean the throats of their De-Soldering Iron tips and irons. It has a wide range of cleaning wires, each having a textured metal finish to burnish the insides of the desoldering iron tips and tool throat, but, also work well for burnishing the insides of the tube sockets. I've attached a link to Newark's listing of the item, which also has the data sheet for the cleaning tool, On the larger power tube sockets, pipe cleaners work, dipped in DeOxit.
https://www.newark.com/pace/6993-020...it/dp/70C2397#This isn't the future I signed up for.
- Likes 1
This is the socket that needs cleaning and tightening. As you see its a lot of wires to desolder and if i can clean it with deoxit d5 and GUM dental proxabrush it is more practical. Amazon sell a deoxit tube socket cleaning kit but i dont think you should be using any kind of chemicals on those terminals.
I use a fibre glass pencil to remove the carbon deposits and prolong the life of the contact spring. Fibre glass does not remove any metal, just residue and carbon build up.
If the contacts are scraped, the conductive material is worn away and it will never recover.
Desoldering tip cleaners, are like a file and do more harm than good in the long run.
If in doubt, replace the socket and it won't come back as a free repair at your cost!Support for Fender, Laney, Marshall, Mesa, VOX and many more. https://jonsnell.co.uk
- Likes 1
Originally posted by jalexquijano View PostThis is the socket that needs cleaning and tightening. As you see its a lot of wires to desolder and if i can clean it with deoxit d5 and GUM dental proxabrush it is more practical. Amazon sell a deoxit tube socket cleaning kit but i dont think you should be using any kind of chemicals on those terminals.
The more tricky part is the re-tensioning of the socket contacts. I use a strong steel needle (e.g. the type used with pinboards).
Tube pins can be cleaned with a piece of folded 400 to1000 grid emery paper.Last edited by Helmholtz; 07-22-2020, 10:55 PM.- Own Opinions Only -
- Likes 1
Originally posted by Jon Snell View PostI use a fibre glass pencil to remove the carbon deposits and prolong the life of the contact spring. Fibre glass does not remove any metal, just residue and carbon build up.
If in doubt, replace the socket and it won't come back as a free repair at your cost!Logic is an organized way of going wrong with confidence
I hadn't thought of small dia fiber glass rod material for contact cleaning. I like that idea. I'll have to see what's available in 'standard' inventoried diameters of that material. 'Typical' 9-pin tube pins range from 0.92 to 0.97 mm dia while the power tubes range from 2.24 to 2.30 mm dia.Logic is an organized way of going wrong with confidence
Originally posted by jalexquijano View Postits a lot of wires to desolder and if i can clean it with deoxit d5 and GUM dental proxabrush it is more practical. Amazon sell a deoxit tube socket cleaning kit but i dont think you should be using any kind of chemicals on those terminals.
Yes it's best to get it done by cleaning, but there comes a time if it doesn't resolve well, you'll have to go through the hassle of replacing the socket. All in a day's work... frustration is part of the job all too often.
Originally posted by Jon Snell View Post......If the contacts are scraped, the conductive material is worn away and it will never recover.
Desoldering tip cleaners, are like a file and do more harm than good in the long run......"I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
- Likes 1
i always use the least destructive method. Some old contacts are tin plated steel and when the tin is gone make a poor contact, some are tin plated brass and do not suffer from wear in the same way. Without being there to work on them, it is guess work.
Sometimes a spray of contact cleaner will work but it depends on the circumstances including the age of the sockets.
Most older McMurdo sockets I successfully replace the connectors and leave the original bakelite bases. Easier and quicker than replacing the sockets but International Octal bases are generally OK after cleaning and re tensioning the contacts.
There are many variables.
A couple of things in response;
I posted about re-tensioning the sockets a while back. I'll try and find the thread as an example of the tool and technique I've had a lot of success with.
If any of the socket terminals are heavily built up with oxide and grime, I don't spend the time to try and restore it.
Rather than replace the whole socket, however, I will transplant the socket pin(s) from a new donor socket. Takes no time at all, and is very easy once you've done it.
... ah, here is the "tube socket harpoon", as coined by Leo Gnardo:
https://music-electronics-forum.com/...361#post733361If I have a 50% chance of guessing the right answer, I guess wrong 80% of the time.
- Likes 2
Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
